Are you running a NA sized flywheel? If so, maybe consider the slightly larger TT flywheel, alot more options for higher torque clutches. All you need to do is grind a small area inside the bell housing to clear the clutch and a starter shim.lsxt300z wrote:Hey guys so I'm not usually active on forums but I've run into a small problem with my build.. Over the the last year I built a 4.8 with a t76 car made 540 on 14psi but the clutch is slipping bad.. Its a south bend stage 4 and I need to find a clutch that can handle the power of this setup... I'm running a loj innovations adaptor with the na 300zx trans.. What options do I have with a clutch so I can turn boost up! Thanks in advance
