Turbo lines (Which to use)
Izento
Car: RPS13
So, I think this may be a dumb question, but I'd rather risk sounding stupid now rather than wasting money and being stupid.
http://www.enjukuracing.com/products/*I ... Mount.html
Can I use SS braided lines that are meant for an SR onto my CA? Also, when doing a turbo upgrade, do I replace the gaskets like the turbo inlet gasket, turbine outlet gasket, etc (more so asking if it's common practice to replace them every time (I had replaced the gaskets recently anyway).
float_6969
The lines for the SR will work, but the fitting that connects to the block for the oil feed is wrong and you'll have to get a different fitting. OR you could just get a CA specific kit;
http://www.frsport.com/DIF-10044-Bottom ... 15431.html
The turbo inlet and outlet gaskets can be re-used.
Izento
Car: RPS13
Ok, ty.
