Doya wrote: No Thats not right. Run a line from the port on your wastegate to the turbo. The other port on your wastegate is for a boost controller, but if you aren't going to use one then plug it. Don't let it vent.
The eBay top mount mani's come with a bung welded on for a EGTS(Exhaust Gas Temperature Sensor). If you aren't going to use one, then plug that too. I used JB weld to plug mine.
-Dakota
my wastrgate has been vented to the atmosphere for 2 years - 20,000 miles and no issues . it works correctly . on my install instructions it doesnt mention any thing about pluging the other port off. it needs to breath so that the valve in side there can open and close. imo you have it drawn out correcly. go to tial sport .com and look at the waste gate install diagram in the tech. section you will see that even with a boos controller there should be a vent in the line between that port and the boost controller so im sure that port is ment to be vented.
Modified by ka-t 300 at 7:59 AM 1/11/2010
