thanx i will do thatgoj_cloud wrote:check all of your vaccum lines for leaks, or is tehers leaks in the i/c piping
the fuel pump does not matter on a stock sr im runnin stock fuel pump and its fineS13FASTBACKSR wrote:you might wanna upgrade to the walbro fuel pump..stock fuel pump isnt really cuttin it..also are you running rich at all? if you are running rich you may want to try cleaning your maf and checking the voltage on it as well..also check the voltage of your tps at idle and. w.o.t. throttle
Yes it does. If the fuel pump is not supplying the adequate levels of fuel the car will bog.goj_cloud wrote:the fuel pump does not matter on a stock sr im runnin stock fuel pump and its fine
got your mailDrifterProdigy85 wrote:stock fuel pump supplies enough for for a Stock 7psi T25 SR. My vote is for a boost leak as well.
