Chris28 »
https://forums.nicoclub.com/chris28-u70836.html
Wed Oct 22, 2008 9:23 am
Ebay intercoolers are good, as well as piping. I would watch out for manifolds, but the SSA bottom mount t2 mani's are probably the best ebay ones you can get. They are the only company that I know of that has gone back and modified their design based on input from people running their setups. If you are going bottom mount and want to run a t25 or t28, get the ssa one. As far as ecu, it is possible to run the stock ecu with stock injectors if you have an fmu, but that setup is not very reliable past 5 or so psi. If you are serious about your build then I would suggest an enthalpy or JWT tune, they have proven themselves to be reliable.
