Turbo kit parts list Wrong?
SumoBrian
Car: 240sx
Hey i just wanted to see if i could buy a good amount of parts right now/last night. I got $1700 came to $1600 + or - some.
So What did i do wrong or right?
FMAX KA24DE Turbo manifold- $125 used - 240sxmotoring-- Your pick JGS mani and dump pipeT3/T4 -50 trim turbo- 600 used -240sxmotoring-- Get new oneCustom Downpipe-??? Custom Intercoler Piping-???FMIC-Evo?-$100-$150-used- ebay HKS SSQV-$160- ebay--- 370cc- $100-used ebay--- Your pick is biggerSAFC II -$150 ebayRising Rate Fuel Pressure Regulator - $100- ebay--- I think thats a FMU? you say no.Oil Line Kit- $90 -jgstools.comNGK Iridium BKR5EIX-11 plugs- $30- ebayZ32 MAF - $100- ebayWALBRO 255 Pump - $85- NewWastegate
Modified by SumoBrian at 10:09 PM 1/12/2007
Modified by SumoBrian at 1:20 AM 1/14/2007
Modified by SumoBrian at 1:22 AM 1/14/2007
Modified by SumoBrian at 1:23 AM 1/14/2007
Modified by SumoBrian at 1:29 AM 1/14/2007
HaXoRsMoBiLe
Car: 2x 90' hatches KAT and RB20
i would personally go with the JGS mani and dump pipe, that way you can use a stock or aftermarket SR downpipe, i personally own the JGS mani and dump and wastegate, they are very good quality.(looks a lot like that fmax mani, cept turbo is placed a little bit further up, which gives more clearance with the master cyl)your gonna need a wastegate too! tial, turbonetics,jgs,etc make good ones.and i dont like FMUs you'd probably be maxing out those 370cc injectors before you max out the MAF, so yeah maybe take that off the list or get bigger injectors depending on how much power you want.as far as the FMIC, the piping will probably be the same as any sr kit, except the hot pipe, home depot FTWwith that turbo your going to have to run water lines to and from the turbo, so thats some more to consider(not as expensive as oil lines).-Paul
98240
T3/T4 -50 trim turbo- 600 used -240sxmotoringwhy get this used for 600 when you can get a new one for $618?
PapaSmurf2k3
Site Admin
Yeah If I were you, I'd get rid of the FMU and take the money you save from that and buy bigger injectors. The SAFC will adjust just fine without an FMU.
SumoBrian
Car: 240sx
ok.cool, This my first time tring to learn how to piece togeather a kit.
I was tring to do what that other member did for $800.
PapaSmurf2k3
Site Admin
No problem man, I think I made a thread like this like 2 or 3 years ago or something.
