Rekless KA »
https://forums.nicoclub.com/rekless-ka-u41940.html
Fri Dec 19, 2008 8:20 pm
just by the fact that your in the kA24DE/DET forum page of course you will get more people saying KA...
which i agree to a point
KA's are amazing, last through sooo much on stock potential, your motor sounds like its pretty healthy, 9:5-1 compression is stock i believe, if you have more with a decent anount of miles on it say 110,000y ou could run some engine cleaner/synthetic oil/ATF(for ten minutes tops at idle if strait ATF not mixing with oil, or 3 quarts oil 1 quart ATF) that could possibly clean some gunk up and out making compression lower.
swaps are simple for the most part IF you want a swap and leave it and not touch it and be happy afterwards, if you wanna modify swap SR is cheaper to get parts for than KA and every other decent swap, but i have put just SR injectors and SR turbo on my KA and raced a SR swapped carand beat it same amount of boost and everything.
i dont have much more off the top of my head for info cuz its really late, time for bed!
