Turbo KA24E oil Supply
narshell
Car: drag racing
Where do I tap the oil supply from on my KA24E(T), and where on the pan do bore for the oil return???
driftin8ez
Car: 92 Coupe, Turbo Miata
I dont know much about this but i saw this while cruising PDM-Racing and maybe it will help. Here is the linkPDM-Racing its called a TransDapt Oil Filter Sandwich Adapter
s13sr20chris
oil filter sandwiches are ok for some stuff, but i shy away from them as they cause the engine to run without oil pressure a little longer. try to get some from the oil pressure sending unit hole.
