turbo ka24de install
tony/ka24de
i'm putting in my turbo. I need to know where the two vacume lines from the throttle body go to when boosted.
encasemyheart
to the intake pipe before the turbo.
tony/ka24de
The line from the valve cover is going before the turbo. I need to know where the two vacuum lines from the throttle body go to. I think the small one goes to the blow off valve and the other to the inter-cooler piping.
gyfer
line from valve cover : you should vent into atmosphere... the fume would clog up your intercooler.. or causing nasty oil in your intercooler.
vacuum line: It is after throttle plate, or before ? Before should go boost gauge/wastegate ... after should go FMU, etc.
PMan_S13
Car: Building car -> breaking car -> fixing car -> start over
I understand where the PCV should be run.. (atmosphere)
But I don't understand where the two small lines should go to..
they are the one that are about 1/2" in diameter (one being a little bit smaller than the other one)'
I would imagine that the one after the throttle plate would have to see boost anyway so it should plug in after the turbo, right?
I'm not sure about the other one, though.. any help?
Also, is there a third large diameter hose that comes from under the intake pipe and goes to, possibly, the radiator?
I haven't actually gotten around to taking any of the stock intake plumbing off and I'm wondering what I'm in for..
