I'm currently in the process of building a KA forged turbo engine and want to install a good and boost capable headgasket. So far the options I have found (including ARP Studs) are:
* Use a FelPro or Nissan OEM headgasket and do an O'Ring job to the block.
* Use a Copper headgasket from SCE
* Use a Steel headgasket from
http://www.back-yard-productions.com/KASTHD1.jpg
* Use a combination of Copper headgasket with an O'Ring job on the block.
* Any other possible alternative/combinations???
Please comment with your "Real World" facts and experience.
Does anyone know who makes the steel headgasket that Back-Yard-Productions advertise and sells in their Web Site? Has anyone used this headgasket? If someone has used it or seen it personally then please comment on its quality, finish and fitment.
What should be a safe torque spec for ARP's KA head studs? Should stock torque specs be retained or a slight increase in torque help without causing more problems that it solves?
