klattr1 »
https://forums.nicoclub.com/klattr1-u1743.html
Thu May 13, 2004 8:32 pm
well, the leaking water came from both sides it seemed like. It started off leaking some right underneath #1 cylinder area of the intake manifold. Then I tightened down all the intake manifolds bolts to see if it would fix it and then filled the rest of the coolant in. Well, as soon as I started it up, it did run funny but I thought that was because of the coolant getting in #1 cylinder(I found coolant on #1 spark plug before compression test). So it appears thats theres no damage as of now. The cylinders are making good compression(what they are supposed to be finally!) but now I have a leaking issue. This couldnt be something thats not obvious could it? I assume its a warped head since I overheated and blew the headgasket previously but I'm not sure until I take it to the machine shop. After I pull it off tomorrow, I'm gonna inspect every inch of the surface of the block and head and make sure the machine shop checks it for cracks and warpage!Thanks WD
