Blow-by won't have an effect on the level of boost being run. Creep is caused by a faulty wastegate or too small of a restriction in the exhaust. That's about it.Logan76 wrote:mine creeps to 11 psi when im at WOT, Im assuming its from my full 3" turbo back, and thats blow by, it could be from your turbo or it could be from piston ring wear, but expect a little blow by because im assuming you dont have a catch can installed? does it have any shaft play?
Ahh my bad.Logan76 wrote:I was refering to him saying about the oil in his intake.
Thats sounds about right. Im going to test that tomorrow, Im just going to shoot air through a vacuum line connected to the wg and see if i can hear leaking and also see how long it holds the pressure.float_6969 wrote:It could be that the actual wastegate actuator has failed. There is a rubber diaphragm in there and if it's failed and leaking, you'll run more boost than normal.
