turbo is fried ??
onevia1800cc
Car: 1989 240sx ps13
ok everything is gravy. take my s13 out for a spin. get to stop sign pull away, build 10\12 psi i cant tell my gauge reads bar. get to about 65 mph let off then i go to acellerate again and this time 0 psi ????? car runs perfect but will not build any boost. my turbo is a brand new t28 maybe 35 miles on it from me. i've unhooked my piping and the turbo pushes air but it doesn't seem like much. oh and now it smokes it didn't before. i hope this turbo isn't fried
float_6969
I've never heard of a turbo actually seizing up and not making boost before. Does it feel like the turbo isn't making any boost, or did the gauge just say that.
nismoplsr
check your wastegate actuator. If the arm fell off the wastegate will be open all the time and you might be lucky to build 2-3 psi at redline.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
nismoplsr wrote:check your wastegate actuator. If the arm fell off the wastegate will be open all the time and you might be lucky to build 2-3 psi at redline.
haha, that's what I was thinking.... happened to me before on another car. I was like, "WTF?????"
CA19DET
did yopu put back the oil restrictor, you may have blown out teh seals with too much oil pressure.. either that or you oil line might be clocked causing it to seize??
in any case, a new T28 - i would send that sucker right back where it came from for a replacement
slownslurious
even if he blew the oil seals he should be seeing some pressure... I'd defintely check the wastegate for problems. The smoking thing sounds like it could be the seals though.
onevia1800cc
yeah i checked the wastegate. it's not that, shouldn't the turbo blow alot of air at idle if i remove the piping??
onevia1800cc
the car run's like it was N\A ???
CA19DET
did you check to see if you blew an intercooler pipe off??
sounds like it, you may be running rich too, making it smoke..
check your charge system for leaks..
CA19DET
and the car will not make boost without load
unless your timing is facked up..
onevia1800cc
ok updatei took the t28 off that !@#$% is FRIED!! exhaust side seals toast, intake wheel is done. shaft is benti have no idea what caused this to happen, no kinks in the oil linesi reinstalled the t25 and she runs PERFECT!!!!i got this turbo off ebay the ones that are 625 shippedPOS IN A BOXi swear i didn't put more than 10 miles on that turbo?????????time to AGGREVATE THE HELL out of that company on ebaygood thing the listing included a 90 day warrentythis ish had better be under warrenty or i'm gonna flip
Modified by onevia1800cc at 7:37 PM 6/8/2005
float_6969
That's a bad deal man. Let us know what company it was and how they handle the sitation.
mbmbmb23
Oh no....was it a "stone mountain" SSAUTOCHROME turbo?
-m
slownslurious
2nd that, post the seller.
onevia1800cc
this link was the auction
http://cgi.ebay.com/ebaymotors...%3AIT
CA19DET
sounds like a home rebuilt turbo, not balanced ata ll.. amke sure you persue this
slownslurious
thats weird, ssautochrome left HIM negative feedback accusing HIM of selling junky turbos.just weird...
onevia1800cc
yeah i'll post pics off the wheels soon
float_6969
slownslurious wrote:thats weird, ssautochrome left HIM negative feedback accusing HIM of selling junky turbos.just weird...
Now THAT says something. Thank goodness for feedback...
c-rad
Here is a lesson for all of you....
NEVER buy a used/rebuilt turbo. The only way I would buy a rebuilt turbo is if it was by a reputable turbocharger company such as Forced Performance. I like the ones that say they are selling rebuilt ball-bearing turbos. As far as I know, you cannot rebuild those....the whole CHRA needs to be replaced.
--Learn from my mistake--On my last car ('95 turbo Eclipse) I went through FOUR used TD05-14b turbo's before I said **** it and got a brand new 16G. The 14b's I got for around $100 each. Factor in the downtime of the car to swap it, and the synthetic oil change I had to do everytime and you are looking at around $520. The EVO3 16G I bought was $569 shipped brand new with all the gaskets and washers I needed. Save yourself the hassle and save up and buy a NEW turbo. You won't regret it.
float_6969
There is SOME rebuilding that can be done to a BB turbo, but very little. I had my S14 turbo rebuilt, and all they really did was replace some seals. The thing that doesn't normally happen is the balancing of the shaft after the rebuild. I called A LOT of places before I found someplace that did it correctly. I haven't had any problems with it so far. (it's got about 300 miles on it)
