Turbo insulation
xsublimefrekx
Car: 1991 s13. SR20det, 1998 s14
I am having a problem with my turbo melting my master cylinder and i was wondering what you guys use for heat wrap or whatever you guys use.Thanks
S13FASTBACKSR
Car: '92 Fastback SR powered
enjuku racing has a turbo heat blanket made to protect components in your engine bay such as your master cylinder from getting too hot/melting. enjukuracing.com under sr20det then under turbo upgrades on the second page.
Modified by S13FASTBACKSR at 2:57 PM 8/28/2006
xsublimefrekx
thanks for the help
Spun180
Car: 91 Black Hicas Fastback
yep had the same problem. Mine actually melted a hole through the master cylinder cup. Just like the above post. Enjuku has them and so does phase2. A little expensive but well worth it.
