nismo dreaming »
https://forums.nicoclub.com/nismo-dreaming-u34698.html
Thu May 29, 2008 8:26 am
Setup: 97 ka24det, stock block, AEM EMS, AEM 3.5 bar map, t3/t4 turbonetics turbo, xcessive intake manifold, ssautochrome exhaust manifold, tial wastegate, greddy front mount, AMS fuel kit with 50lb injectors, fuel pressure is set at 43 psi., Walbro 255.
After installing all turbo material, I had some issues with my CAS not syncing with my ems. After doing an extensive search on my factory harness to find nothing, I replaced it with a 96 obd2 harness from a local junkyard. The new harness fixed the issue, and I even got a few back fires. I then rerouted the wiring below the intake manifold ( to clean up the mess) and everytime I crank, I have 0 spark. The S tooth is still connecting, but when placing the spark plug wire near a ground source, I have no ark. I have swapped out distributors, spark plug wires, changed the internal coil on the ems from coil #1 to coil #2, and have 12 volts at the coil plug at the distributor. I removed the cap and the distributor shaft is spinning while cranking. All fuses were removed and instpected and show to be fine.
The only thing I could think is maybe a short in the origional harness may have poped both distributor coils when swaping between the two, or maybe a fuse im not familiar with that would be used for this exact spot, but im fresh out of ideas.
If anyone has any ideas, please let me know. This is my daily, and I need it up and running asap .
Thanks
