themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Mon Mar 08, 2010 12:09 am
The stock install includes two metal straps with ears on them. They go on top of the turbo flange but under the nuts and after you tighten the nuts you bend the flanges up so they are flush against the flats of the nuts. I hope that puts the image in your mind effectively. No more problems. You should check the parts book for the 300ZX. If you are using a T3 flange, check the Z31, for a T25 flange, check the Z32.
