Turbo identification conformation and use information
Secret squirrel
Car: 1990 240sx w/ ca18det
ok, this guy on a local board is selling what he says is a s14 T28 turbo
but, it looks like a T3 with a t25 flange. just want to see what u guys think.
so my question is...what is it.
thanks alot
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
got the right exhaust outlet flange, thats for sure. the AR on that compressor looks a little small though.
Car: 1992 240sx coupe
rb26 twin T28s use the same compressor A/R tho. Looks like a T28 to me. Not sure if it's from a S14. A side view would help.
mbmbmb23
This is what your compressor housing is from:
http://cheapturbo.stores.yahoo.net/gat3su.html.42 A/R on a T3 isnt the same as if it were a T2. I'd say the end result would be similar to an S14 T28, maybe slightly less since the S14 turbo has a T04b compressor and not a T3.
-m
float_6969
That is NOT an S14 SR T28. It might flow close to the same amount, but probably not quite as much.
Secret squirrel
thanks for the input guys...so heres another pic.
now if it is a T3 super 60 housing, how will it flow and is it a good quick spool for the ca? My ca is goin to be 90% drift driven so quick spool is important.
SS
NUT-CSE
Car: 1988 Nissan Exa
That isnt a S14 T28, the S14 T28 has a AR .60 compressor housing and AR .64 turbine housing.
Its not a GTR turbo either.
Seems to be a T3 of some kind.
mbmbmb23
I believe the compressor side is equivalent to the GTIR compressor which is a T3 compressor. I think the turbo would do fine, I would run it with stage 3 mods.
-m
Secret squirrel
yea i bought it. the owner claims its a t3 housing with a t28 wheel and exhuast housing...im goin to pick it up later this week. When i get it ill take more detailed pictures. he is giving me a money back option. So if it turns out to be teh ghey, no worries.
and by stage 3 mods...what do u mean.
i will be running these mods:
Blitz FMICWalboro pumpsard fpr550cc injectorsfull turbo back exhuastHKS wastegate (if it mounts up)Megasquirt IIport and polish3 angle valve jobSSauto **** manifoldstock HG with ARP studs
will it be a goood match?
thanks all
SS
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
mbmbmb23 wrote:I believe the compressor side is equivalent to the GTIR compressor which is a T3 compressor. I think the turbo would do fine, I would run it with stage 3 mods.
-m
The GTi-R turbo uses a T04B compressor housing just like the S14-5 GT28R.
Woods Crasher
Secret squirrel wrote:but, it looks like a T3 with a t25 flange. just want to see what u guys think.
Correct me if I'm wrong, but isn't a T3 compressor with a T25 turbine what makes a T28 a T28?
mbmbmb23
Nope, the GTI-R turbo's compressor is a T3 super 60. Theres a thread on one of the forums where they put the S14 compressor housing and wheel on a GTIR turbo and it was good for 315-320hp (on an SR) vs around 300hp they were seeing with the OEM GTI-R unit.
http://importnut.net/turbosizing.htm
CadetLD
Car: 1991 Nissan 240sx Coupe
Not trying to destract the thread but thgat does A/R mean?
NUT-CSE
The larger the a/r, the longer the turbo will lag, but the more potential it has for top end power.
Abit more technical
A/R ratios are ways of further sub-classifying compressors as well as turbine housings by offering differing flow characteristics within equally sized housings. The A/R is calculated by dividing the inlet (compressor) or discharge (turbine) diameter’s cross-sectional area by the distance between the center of the wheel’s shaft and the center of the measured inlet or discharge area. When calculated correctly, the A/R ratio will remain constant throughout the housing. Varying the A/R affects compressor performance little but the same cannot be said of turbine housings.
Masterdebater
Car: 1989 nissan 240sx coupe
i have a s14 t28 turbo...that is most definately not an s14 t28...i have no idea what that is...
CadetLD
thanks for the clarification nut-cse but what does the A and the R mean?
NUT-CSE
A/R (Area/Radius)
c-rad
Car: 1991 Nissan 240SX w/CA18DET
CadetLD wrote:thanks for the clarification nut-cse but what does the A and the R mean?
http://www.turbobygarrett.com/....html
Secret squirrel
picked up the turbo tonight...here are more detailed pictures.
Stock CA turbo on the left
Secret squirrel
says .64 on the turbine side.
so .42 compressor and .64 exhuast...
SS
NUT-CSE
Does it have a serial number on it??
Its a turbo of a GTR but there are 11 variants of this turbo.....
Secret squirrel
The identification plackard on the center section is missing. WHere else could i find the serial number?
SS
NUT-CSE
I wouldnt kno? Once its gone, its gone forever.
You could measure the compressor and exhaust wheels and you could match them to one on the list.
To me it looks like it would be the R33 N1 turbo, maybe the Nismo 260RS or Nismo R1 but its anyones guess.
http://homepage.ntlworld.com/tbroom/Turbos.htm
Modified by NUT-CSE at 7:54 AM 3/30/2007
