theBird »
https://forums.nicoclub.com/thebird-u68682.html
Mon Dec 14, 2009 9:22 pm
I can normally find an answer to any question I have by searching but after two hours, here I am.
My daily driver stock red top with a t28 and just tonight the turbo has started making a supercharger-type sound only when its boosting. The sound is consistent 1 psi up to 9 psi. In other words, the normal hiss has been replaced with a slightly louder whine. Everything seems normal except for that noise. Oil pressure is fine. It still makes good power with no smoke, no strange smell, no liquid leaks and as far as I can tell no exhaust leaks. I replaced the turbo to manifold and manifold to block gaskets and bolts about 6 months ago and it doesn't sound like its the same problem as before with the bolts coming loose.
Are these symptoms of a bad turbo or could it just be a boost leak?
I'll post a clip if necessary.
