t.mcginley.jr »
https://forums.nicoclub.com/t-mcginley-jr-u204971.html
Fri Dec 20, 2013 6:23 pm
There's no brand name stamped on them or ID plate of any kind?? If not then I would assume China turbos
Do they look like they were balanced at all? You can tell by looking at the shaft nuts, they usually have spots grinded down/off. If not and you plan on using them, I would definitely get them balanced by a shop. Balancing a turbo, even a cheap one, is crucial to how long they last. Not being balanced from the factory is the main reason cheap turbos fail.
