jeremy_gass »
https://forums.nicoclub.com/jeremy-gass-u96708.html
Sat Jan 02, 2010 2:58 pm
i want fast spool for now, and about 300hp down the road, looking to keep stock tune for now, so it would work fine with a external wg set for 7 or 8lbs with stock ecu? also will be a top mount. since it does not use water just oil, do i just plug the water line on the block? already removed the water line on the back so it fits in the car....
