turbo help
chestersnet
Car: 180sx sr20det
my t28 turbo is dead
i have my eyes on the gt28rs
is anyone running this turbo on their sr????
what supporting mods do u have..?
i have 3 inch exhuastfmicwalbro fuel pumpstock injectorsact clutch
with stock 375 injectors what is the most boost i can runwith 550's and a piggyback what quatermile range might i be in?
chestersnet
Car: 180sx sr20det
come on nah guys
i tried searching but not gettin an info
cheapscheisst
Car: 1996 240sx w/ Kouki front end
get the GT2871r .64 trim. that way, you can make far more power when you upgrade to 550s and a piggyback. with that setup i believe you can make around 320 whp and run mid to low 12s in the quarter.
cheapscheisst
also get the MR exhaust manifold and a downpipe. better airflow is a must.
chestersnet
Car: 180sx sr20det
MR as in evolution???
nwmrkt
Car: S13
Megan Racing, its a brand.
chestersnet
Car: 180sx sr20det
can i use this setup with my stock internals....?
how much boost can stock internals handle
whats the most boost i can run with this turbo?
cheapscheisst
1. yes, easily2. more than the turbo can safely take. however, without an aftermarket cam setup, you won't make near as much power as is possible with this turbo.3. around 20-22 psi
AmoebAssassin
Car: 1991 Base fastback 5spd, black
You can't run more than like, 8lbs with stock injectors on a GT28RS.
With 550cc injectors, like 20lbs -- this is good for mid-low 12s.
eazye2000
Car: S13 KA-DET
Hey there. I'm just browsing the forums trying to see if anyone wants a REAL Garrett GT28RS.. I had it on my KA-T, but T2 is way too small for the KA. I'm going T3. I have the GT28RS with .86 AR exhaust housing. Compressor Wheel Exducer Diameter: 60mm - 62 Trim Exhaust Wheel Inducer Diameter: 53.85mm - 76 TrimI was running 12psi on my KA spooling crazy quick. I had 10psi by 2200rpm, but I don't know what it will do on a 2.0 SR. I'm getting rid of it because after about 1k miles, I broke the ring lands on my pistons. I'm going T3 with my motor after the fresh rebuild in hopes in can breath a bit easier.If you're interested, e-mail me at:[email protected] <--MSN as wellI can snap a few pics of it if you want. I still have the original papers and the Garrett box it came in.
Thanks,Eric
SR20Monster
Hey I've got one of those manifolds for sale.. It's not Megan Racing, it's an SS autochrome one that has been reinforced and ceramic coated.. probably the best mods that can be done to these manifolds. It's made of really thick steel too.. Just email me if you are interested- Sergio
[email protected]
SR20Monster
I can also get you some pictures if you are really interested- Sergio
