jdmser »
https://forums.nicoclub.com/jdmser-u10477.html
Fri Oct 07, 2005 7:58 am
Thought I had a boost leak, but wasnt able to find one. Then the problem went away on its own or so I thought. Couple days went by when I was on the way to work I got off of the freeway and came to a stop. When I took off I had no boost in 1st, 5psi in 2nd, and full boost in 3rd but not until 4500rpms. I put a dial indicator on the turbo today and got 0.013"(spec is 0.0005-0.0038) of thrust play and the waste gate didn't move until I had 20psi on it. Just want to make sure that this means the turbo is stuffed. If so I want to upgrade, but dont have to money for injectors and fuel management right now. What turbo could I go with that would be ok for now and get me to 300-350hp when Im ready for injector and fuel management? I'm on a buget so I'd like to stay around the $600-$700 range.
