evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu May 01, 2008 7:58 am
the head can be repaired, they have to heat it open the crack, fill with weld, then mill it back to shape, it would likely be cheaper to buy a P90, as for block strength, the F54 is siameased every other bore, #1&2, 3&4, 5&6, the N42 has all 6 siameased together, there are arguments boths ways as to which is better but my personal opinion is that it doesn't matter, there have been a large number of each bored .120 and turbo'd without issue, thats not to say there were not some failures, the castings on these things are not as precise as we would all like so sometimes you get one where the walls are a bit thin on one side as the bores aren't as centered as they should be, these are made of high nickel steel, and much stronger than most domestic castings
I say keep an eye out for a P90, and it's always easier if you have a complete donor car
