Moose 45 wrote:This is what i need to know. Is there kits out there to upgrade the internals to hold that performance. Because STS is predicting that at 7-8psi and it will be around 450 maybe 480hp with the stock set up. Of course upgraded fuel system and oil pump set up will hopefully help. but will i need more for the motor before i do the bolt on package. Also some help from some techs would be great. These guys here in Denver at the dealership will not talk to me about this or give me any input. Yada yada yada. Morale of the story is that i want to build a sleeper and i have built many other cars 300zx 93 @ stage 7 at 750 hp, street strip trans am with 625hp stroker motor and as well as twin turbos mustangs in Texas part of the Texas turbos club. PLease any input will be great. Because if all fails i'll just do a motor swap fx35 turbo drop in by APS. Seriuos inquiries only. Because i love the vehicle and it would be fun to play with some of the big boys out there.
http://cgi.ebay.com/ebaymotors...ories
Call 877-772-0338, ask for Eric.
How much you looking to spend? Swap in a VK56DE from a nissan titan or infiniti QX56. Engine mates to transmission, but engine mounts and others were slightly modified. Then throw on the bolt-on Stillen supercharger and you should be able to have a reliable torque monster.
Or, have Eric make you some pistons, buy some new rods, then use a STS rear mount turbo.
Go big? Sell your FX45, buy the cheapest 2003 FX35 you can find. Rebuild the engine and throw on a Jim Wolf Twin Turbo, and you can have 500 wheel hp on pump gas. VQ35DE has been around the block and tuners have figured out what works and what doesn't. 350z, G35 turbos fit with little modification and you have nearly twice the engine bay room to work with.
You're talking about $20,000 for the engine rebuild + Twin Turbo + Tune if you do it right.
Keep us updated in what you do.
