TURBO FRUSTRATION!
RBrum
Car: 09 Mazdaspeed 3, 92 silvia converted 240sx
ive been searching for the past 3 days trying to find answers on how to clock this turbo or if i need an adapter or something.. and i cant find anything.
here is my exact problem.. I have a disco potato (gt2860rs) the wastegate bracket is in the way to clock this turbo. could i take the bracket off clock the compressor side like the stock turbo position then remount the bracket underneath? or do i need to get a different bracket? or should i just sell this annoying turbo and get something else.
ANY TIPS or HELP will really be appreciated.
RBrum
RBrum
any suggestions!?
240trackjunkie
Car: 1990 Nissan 240sx
ATP says this is for transverse (fwd) applications, not rwd. Might still work tho. Is this an actual Garrett turbo?
RBrum
yes it is a garrett turbo
240trackjunkie
this is how it should look... got this from Sport Compact Car magazine's project silvia...
"For proper fitment, the turbine and center housing have to be aligned just as they were on the stock turbo. Using this cheap bubble level, we were able to measure the angle of the oil drain flange with the turbine intake flat on the ground (or a roll of duct tape) and duplicate that alignment on the Potato. The compressor housing alignment was based on alignment of the wastegate actuator and clearance of the manifold. We had to flip the actuator bracket around backward and trim the stock exhaust manifold heat shield, but nothing had to be fabricated to make this fit. "
Modified by 240trackjunkie at 7:41 AM 1/6/2010
RBrum
thank you that really helps so i would just have to clock it and they said flip the bracket around? ill experiment. its ok if i take those bolts that hold the bracket on off ? i know i was reading something where u shouldnt take the bolts out?
240trackjunkie
Yeah, looks like all you need to do is reclock the compressor housing and flip the bracket around like they said. Never heard anything like that about the bracket bolts. I've personally removed / replaced many of them without any issues.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
Im running a 2871r that had the same issue, i had to flip and re-drill holes in the bracket to position my waste gate properly
RBrum
wow this could finally be the answer to my problems!
RBrum
RBrum
240life
wtf
