Turbocharger kits will be limited in how much they will yield because the Xtronic is designed to handle only a certain amount of torque. Any significant boost in power on a Rogue will require modifications to the transmission to deal with it. That definitely adds development time to potential power packages.albertwang16 wrote:is it possible to have a turbo put inside the rogue in the future? is there anything you can do to increase some horse power?
Not when gas gets to $5 or $6 a gallon.amr40509 wrote:I would more expect to see a 3.5L V6 come out in a couple of years when people get tired of the little 4 banger.
This has to be one of the most ignorat post i've read on here so far. Just because a four cylinder has less cylinders than a 6 cylinder doesn't mean it works any harder for the power it produces.amr40509 wrote:I wouldn't expect to see much loss of MPG w/ more power. Basically a small motor working hard is going to burn just as much as a bigger motor not having to work hard. Now if you keep your foot into it all the time, more power will burn more gas.
My 4X4 Pathfinder has 100 more horse power then my wife's Rogue (4.0L V6 rated in 2006 at 270bhp). On the highway I get about 22mpg. She gets about 23-24 on the same stretch of road in her AWD Rogue at the same speeds. She does kill me around town though, but I would say this is due to the extra weight of my truck, not the power level.
You'd have to swap for the unit that comes on the Murano or Maxima; it is a larger, beefier model than the unit in the Sentra/Rogue (both models can be seen on the JATCO web site). I do not know if the Altima uses the same unit for both engines or if it uses the beefier unit only for 3.5SE models and then the smaller unit for 2.5 models. If the Altima uses just the larger Xtronic, then there may be an easy way to adapt the larger Xtronic to the Rogue's engine.Eikon wrote:mmm Turbos!!!
Now you're speaking my language.
Sure you can put a Turbo on a Rogue! You won't find any companies that will likely release a kit that is mass produced.
I'd start researching the Sentra SE-R turbo options as they share the same engine.. hence the exhaust manifolds that are specifically built for that engine wil not have to be custom made.
It won't be cheap, and it won't be common.. but people will do it!
I don't think the transmission will give any problems for a mild turbo kit. Say you bump hp from 175 to 225ish.. That would make the Rogue a real kick to drive.. and that trans is the same as the 265hp V6 Maxima/Murano, etc..
Who's gonna build the first Turbo Rogue?????
Thread from the dead. If the X-Trail uses the same trans, then there might be no issues with a turbo'd 2.5l Rogue. The X-Trail came with a SR20VET pumping out 280HP. If the X-Trail can handle that power, so can a Rogue. But the X-Trail did get redesigned in '08 and is running different engines, the MR20DE and QR25DE, so who knows... ????EddNog wrote:EDIT: Here, see this page; the JF010E is used for Murano, Maxima and Altima (Teana), whereas the JF011E is what's used for Rogue (Dualis, X-Trail).Modified by EddNog at 9:30 AM 4/13/2008
The only X-Trail that came with the SR20VET is the 1st gen model from '00-06. This is a completely different platform than the Rogue. The SR20 was discontinued in favor of the MR and QR motors once the new X-Trail came out.nismopc wrote:Thread from the dead. If the X-Trail uses the same trans, then there might be no issues with a turbo'd 2.5l Rogue. The X-Trail came with a SR20VET pumping out 280HP. If the X-Trail can handle that power, so can a Rogue. But the X-Trail did get redesigned in '08 and is running different engines, the MR20DE and QR25DE, so who knows... ????
The problem with any motor swap is there are so many interconnected systems and electronics nowadays it would nearly impossible. The engine ECU, trans ECU, ABS, VDC, AWD computer, etc all talk to each other... it's more than just a motor and trans.
The simplest way is to just lightly boost (5-7psi) the stock motor and cross your fingers it doesn't break!
