knightrider4 »
https://forums.nicoclub.com/knightrider4-u37973.html
Thu Aug 16, 2007 5:13 pm
I will let you know how much lag there is with the 35r soon It also depends on if you have the money to do a twin scrol setup. Then you could do a nice T4 35r set up. with the twin scroll setup i would expect you to see full boost anywhere from 3900-4300 depending on your turbine A/R housing. single scroll figure a few hundred RPM's more. Again i can't stress this enough with a ball bearing turbo your transient response will make it feel like it spools earlier, harder, and more linear. ball bearing-non ballbearing are different ball games
