it all depends on your manifold design. there are some that direct exhaust up to the front of the engine compartment where the airbox used to be. others just fit it into the back.
most street turbos that I have seen are pretty much the same size, give or take an inch per radius. the biggest problem with fittment is the exhaust housing, and likely you will get something with a T3, which is easy to fit, but it just requires a good manifold.
check mine outhttp://
www.andrew.cmu.edu/~shersman/car.html
there are a couple of pics(link at the bottom) , it wasnt much custom work, and it produces a lot more power than it did before.
Steve
