Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Thu May 21, 2009 6:15 am
Alot of guys go with the GT30R.
You could go with a HX35 or some other Holset, not quite sure about the sizes.MUCCCHHHH cheaper than a GT turbo.You would have to seal the Interal WG passage though.
You could go with a T3/T4 turbo, you can find one that will bolt up to all of your pipes.Not sure about the Hot pipe though depeneds on your setup.
But if you switch turbos, you will most likely have to modify your downpipe flange, your hotpipe and maybe some oil/water lines (don't think you would have to though).
The real question to answer your question is:
How much power do you want?
