ok here we go. So I have a Disco Potato/gt28rs, i finally get in the car, after a 6 months seating in my house, i used the taka lines lines with the stock banjo fitting bolt from the stock black top sr, my car smokes, big time, bluish smoke burning oil, brand new turbo, i havent driven the car i just started and it smokes so no miles into the turbo yet, here's what i think could be happening, im not sure so guys please help
first time i got the car together it smoked, i took the turbo out and it was the oil return line, it was kinked, so I thought the problem was fixed, but guess what, it whasn't. I'm using the stock bolt which is suppost to be a restrictor but i think the lines have a restrictor too, or is it just so you can use the stock restrictor bolt?
zerothread?id=182047
I was reading an article on markemark article the one above, and i thought that my probrem was similar, so i keep searching and i find another article saying that new garret turbos come with a restrictor built into the turbo, so now markemark said that turbo seal falure is becouse not enoght oil goes into the turbo, could that be it, the opposite problem that i had before, with my oil return line kinked?, could my problem be that im using a stock sr banjo bolt restrictor, the lines may have a restrictor in them too, and the turbo has a restrictor too? wtf.
thats 2 or 3 restrictors im not sure, shoul i run the car with no restrictor at all or may be is put back together right, but my turbo seal is bad, which i believe i would need a new turbo because they are not serviseble, that's 1100 dollars that i paid for the turbo f****, im so upset and pissed off, please help before i star braking sh**.
Attachment: phase2motorsports_1913_4714583.gif (2119 bytes, downloaded 6 times)
