C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu Feb 27, 2003 5:30 pm
I noticed a nice increase in response and power when I switched from my 60mm Greddy to my 80mm Greddy. Though it came with a price of more noise. Turbos use a little different approach to exhaust size. While it is good to keep decent velocity, turbines are sensitive to the pressure differential across the turbine wheel. With less backpressure, given the same exhaust manifold pressure, it will spool the turbo faster and run more efficiently, since more air can be diverted through the wastegate for the same boost level. Since air going through the wastegate flows freer(the turbine is a restriction no matter how you look at it), you free up some additonal HP. Generally the rule of thumb for a turbo exhaust is to go as big as your ears can bear.
