This is the description hope this helps people that have the same problem I am not sure how it fits but when I get it i will post and tell everyone how it fits
To View More Information About This & Our Other Products Visit:*
http://www.himniracing.com *2.5" T3 3-Bolt Flange(Turbo To Downpipe Weld Flange)
!!! Brand New !!!
Ah yes... only the best! This flange bolts up to all T3 5_bolt turbine housings that have a 2.5" ID 3-bolt downpipe discharge internal wastegate. Easily welds to any 2.5" downpipe to allow for downpipe to turbo connection.
-- Precision CNC Machined From Billet Mild Steel
-- Thick Solid One Piece design (will not warp like others)
--Great For High Heat Applications
-- 2.5" Inner Diameter (Fits all 2.5" Pipes)
Check of our other auctions for other top notch flanges....we have a bunch. If you don't see something you need, just let us know, odds are, we have it!
:Price Matching:If you find this item for less someplace else, just let us know & we will do our best the beat it!!
Himni Racing is a Discount Retail Supply Shop Of High Quality, High Performance Auto Parts. Whether it's::ACCESSORIES... BLOW OFF VALVES... BOOST CONTROLLERS... BRAKES... CLAMPS... CLUTCHES/ DRIVELINE... COOLING... ELECTRONICS... ENGINE... EXHAUST & MANIFOLDS... FITTINGS & LINES... FLANGES / ADAPTERS... FUEL SUPPLY... GASKETS... GAUGES & PODS... IGNITION... INTAKES / FILTERS... INTERCOOLER PIPES... INTERCOOLERS... INTERIOR SILICONE COUPLERS... SUSPENSION... TURBO ACCESSORIES... TURBOCHARGERS... WASTEGATES & MORE....
Modified by label at 9:04 PM 2/7/2006
