Turbo exhaust Outlet Q.
thekawaii
Car: box with 4 wheels
I have Z31 T3 turbo. The turbo has stock Z31 exhaust outlet with welded steel downpipe.
So, I was reading stuff on Z31 forum, it seems like my turbo outlet is way too small for supporting 300hp well. (They said 280hp)
I found one item was ported and the company said it can flow til 400 dollar, it's fine except it cost 300 us dollar to order one from them. (outlet only, downpipe not included)
The reason I'm trying to use Z31 turbo outlet is, to keep internal wastegate.
help me guys, which outlet can i get? and where for cheap?Any solution?
Chezedik
Car: 1991 Nissan 240sx
Pick up an internal wastegate on ebay for like 5-10 bux, then make a new DP. Also, you may want to look into a bigger wheel (stage 2+).
hannibal
Car: Red Line to Glenmont
Chezedik
That's pretty.
mirra32
is it possible to weld a custom elbow to the stock elbow flange.....
cut flange plust about half an inch from flange and weld up some piping on there.....
Chezedik
Can't weld steel to cast iron, you can only braze. If you aren't careful and temps get too high, it will come apart.
