Turbo Engine Swap 4rm S14 NonABS to S14 ABS
Nismoboii
Car: 1996 240sx
1990 240sx
Ok. thanks for stopping by and taking your time reading this.. I have came across a S14 SE Full Leather, LSD, White Dash Instrumentals. ABS, 5lug etc etc etc.. Down Side.. Its an automatic... My Friend just Crashed his S14 his car was just a base model. 4lug no ABS u guys get the point.. ok here is the deal.
He sold me his Entire engine and Manual transmission with all the necessary wiring and accessories to make it work like the cylinder, clutch pedal, clutch hydrolic line, engine wiring, etc.... its a KA24 Turbo, fully built lot of money on to that power house :naughty: . the ECU is wired weird so i cant use my own wires all and engine wiring is all weird also.. so obviously i need to swap all the wiring but his car was not ABS and my car IS.. will this effect anyting on my breaking system?? and when i went down on my dash board driver side, where the clutch pedal suppose to go there is this lil computer or something, pedal wont fit, or will it fit?? please help.. :frown:
terry_240sx
Car: '93 240sx hatch
What year is your s14 , and what year is his?
terry_240sx
If i were you i would just swap over the manual transmission along with the clutch pedal, master cylinder, etc.
then if you still want to turbocharge it, do it. :yesnod
Nismoboii
Car: 1996 240sx
1990 240sx
the thing is that, the engine i have now.. its BADDD.. heads are bad, water is getting to the oil.. i had to buy that weld powder thinggy for it to temporarily work till the swap.
Nismoboii
Car: 1996 240sx
1990 240sx
terry_240sx wrote:What year is your s14 , and what year is his?
the are both a 95..
Nismoboii
Car: 1996 240sx
1990 240sx
terry_240sx wrote:If i were you i would just swap over the manual transmission along with the clutch pedal, master cylinder, etc.
SiDwAyZ240
Car: 95' SR Slayer, '02 LT Tahoe, '03 Chev Express is the DD
I would like info on the same thing, I have a 95 looking to run a S13 tuned ECU. Does the S13 ECU have to be from a ABS car in order for mine to work? Will it cause and lights or anything cause that makes cars auto fail inspection.
Nismoboii
Car: 1996 240sx
1990 240sx
SiDwAyZ240 wrote:I would like info on the same thing, I have a 95 looking to run a S13 tuned ECU. Does the S13 ECU have to be from a ABS car in order for mine to work? Will it cause and lights or anything cause that makes cars auto fail inspection.
Real Good Question... if the S13 that ur taking the ECU out of has NO ABS, and ur 95 has no ABS it should work or Vise Versa. just make sure that the S13 ECU comes off a DOHC. And if u have No ABS ECU and ABS System on ur car.. then we both are in the same boat. :biggrin: jajajajaja.. and i dont have to worry about Inspections.. I Live in Tijuana. everyting here is Legal.. :cool: have my stock all legal work on a s13 and i have my lil s14 toy.. :woot:
