aleph1 »
https://forums.nicoclub.com/aleph1-u177.html
Thu Jan 29, 2004 9:41 pm
1- No, Greddy kit is still pending CARB legal. In Cali, one of the tests to pass smog is a visual inspection, if the part is not CARB certified, you dont pass. Just another way for the state to make money IMHO. Only solution: Illegal smog check.
2- Technically its possible to pass the smog requirements depending on where you live, turn boost way down and dont remove any emissions equipment from the car. But overall, you cant PASS the whole test, refer to 1.
3- Depends on the cop. Some will think its too loud and stop, with or without a test with a db meter. But in general I wouldnt worry about it. If it is a problem, carry your silencer with you.
4- This has nothing to do with california, its up to you. I wouldnt run more than 9psi on 91 to be safe.
