trevr »
https://forums.nicoclub.com/trevr-u54144.html
Wed Mar 05, 2008 7:42 am
My battery is relocated behind the passenger seat. I run a ground wire to the chassis inside the car, and run a 0 gauge wire to the intake manifold, and split the ground from there to other locations under the hood.
The ground wire connecting to the chassis came loose from the battery terminal. My a/f gauge went to lean, and I could hear the turbo try to spool but the car just bucked and stammered. Reconnected the wire, and all was fine.
