I'm looking to push 350 WHP, and I would like decent spool time. That lead me into researching the 2871R in .64 trim and then I saw the 2876R .64 trim which GARRETT tells me it has the power potential of the 2871R .86 trim and the spool time of the 2871R .64 trim .
The problem with the 2876R is you have to cut the motor mount area to make it fit (bottom-mount setup). If I where to top-mount it, I might as well go with a better turbo setup. Which in turn lead me to Holsets courtesy of this thread:
zer...hread
Now As I said before, I'm looking for 350WHP so would Holset be a bit overkill? The price of the holset is defnately more attractive than the price of the Garrett and I have been hearing that Garrett's qaulity has gone down lately. If I am going to spend $2k on a turbo it'd better F'in last a good while. One last thing, More important to me than making 350WHP is engine response. I don't want a huge laggy a** turbo, RESPONSE is key for me. I don't want a Twin -Scroll setup on this car. Car is a DD with moderate track-use (for now). Once I get better at driving I will re-evaluate the setup and than change things around if need be.
