Turbo Cooling Lines
DanielIser
Car: SR20 Powered '91 240SX
Ok I did a search and didnt really find anything! My question is, I am upgrading to a GT25R and i know it will mount on the stock sr manifold and dump pipe, but what about the hotpipe fittings, the turbo lines etc The turbo lines are my main concern. Will the stock t25 cooling lines work or what? Does the GT have water and oil cooling? or do i plug some of them? Also does anybody have any braided turbo lines for the GT25R that they wanna sell? if needed that is. Thanks!!! Also what is the best price and location to get the turbo lines from if needed!
RobDET
Car: Cars
You should be able to modify the coolant lines to work. A trick is to cut the one that goes from the turbo straight to the block and add about 2 inches of feul line with hose clamps. It makes it WAY easier to move around and install the turbo.
I know Phase 2 has the lines you would need if you want to go the braided route. Also i think the oil return flange is a little different from the 25
