Doogz wrote:
My new turbo does not have any coolant lines on it. just the 2 oil ones. I was just going to go with the turbo timer but do you think i'd need the oil cooler too?
That's a little different. If the turbo was designed WITH coolant lines then it's designed to use that to cool it.If the turbo doesn't have them then it's designed to be "cooled" by the oil.There are internal differences between a water cooled and an oil cooled turbo.
If you plan on running heavy boost OR you abuse your car a lot then you'll save yourself in the long run by having an oil cooler.I hate to bring up a video game but if you've played Tokyo Xtreme racer 3 you'll actually learn a little about how all that works, oil is a thick liquid and it has a high heat capacitance compared to water.. that's why you can use it to deepfry stuff since you can go beyond 100C without oil boiling, problem is it's SLOW to bleed away heat and most cars aren't designed to cool oil directly, it's usually cooled indirectly by the regular coolant in the engine cooling the entire engine. So what does that mean? Say you are beating your car and you run the heat up, both the oil AND the water is getting HOT, problem is when you see it "cool off" or you are just driving sanely for a bit while the water temp drops the oil is still as hot as it was 20 minutes ago..Unlike most of the other racing games TXR3 actually takes that into account and you can be running a nice cool water temp but oil around 110C and blowing up your motor..
This problem is increased by thicker oil, so 20w50 will hold it's heat "better" than say 5w30.
