turbo coolant lines
95_sr20det_240sx
Car: 95 240sx with sr20set
I purchased the circuit sports braided line kit. I have connected the longer line to where the coolant inlet is then to the driver side of the turbo. I am now having trouble with the shorter one. It goes to the side of the block and to the passenger side of the turbo. Right? Does any one have a picture of theirs so i can get an idea of which way to route it. thanks
Last edited by 95_sr20det_240sx on Wed Oct 27, 2010 7:56 pm, edited 1 time in total.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
95_sr20det_240sx
thanks very much found a bunch of info and getting help with the issue
95_sr20det_240sx
Thanks to all I got it finally yesterday. I started it up let it run no leaks in the coolant lines or the oil line. but I did have a fuel leak. lol but thank goodness it was just the fitting that was holding the hose onto the fuel filter. lol tightened it up and it was fine and then took it for a ride and it is good. but then I found another problem. I turned the fan on and it sounds like it has a bunch of crap in the system somewhere. I think where it was in the garage the mice made a bed in the vent system. I changed all the settings and the sound never changed. I think it is in where the fan is. now I just have to find it and take it all apart and clean it out. lol
