turbo coolant lines?????
captainclutchkick
Car: 1990 nissan 240sx coupe with rb25det
i already searched and im going crazy with this so maybee someone on here can andswer my ?'s . i was wondering about the factory rb25 turbo coolant lines, i have a t3/t4 turbo to put on but its only oil cooled and i am wondering what to do about the factory coolant lines, can i block of the coolant feed line where it comes oout of the block and if so what do i do about the return line thayt goes arounfd the back of the engine? where does it go ? im stumped and really need to get my car going and this is my only hangup.
rb guys please help
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Yes you can block the coolant line to the block with a plug. The coolant feed line comes from the top of the intake manifold at the back and runs behind the head. You could just take the rubber hose off of the line connecting to the head and plug it with a rubber plug. They sell misc. rubber caps at any automotive store.
Should be very straight forward.
captainclutchkick
when i looked in the fsm it says the one behind the head is the return line and the one coming from the block under the exhuast manifold is the feed line. can i just cap of the line at the block? then what about the return line behind the head an i just leave itopen or what???
zdonner
Car: 1991 240SX SE Hatch
If you left that open you'd have no pressure in your cooling system!
themadscientist
If you have the money you could use a Nismo force field generator but I would just use a rubber cap.
captainclutchkick
so basically i can put a bolt into the block to cap the coolant feed line, then i can cut the banjo fitting off of the return line and put a cap on it , and its done?
i just wanted to make shure that the return line didnt feed coolant to anywhere else before i went and blocked it off
themadscientist
On the 20 it is a hard line that runs behind the head and then hits a rubber hose somewhere under the intake. I would follow it to that point and wherever the rubber hose comes from cap it there. Don't cut the hard line; some guy with get a motor with a munched one and you will be able to hook him up.
