Turbo confusion
Neejay
I have a SOHC. A lot of people recommend I get a T3 (GT32?) turbo. My dilemma is that a lot of the manifolds I see are for the "T3/T4" bolt pattern. Does this mean that I can use that manifold with the T3 OR the T4 or just for a T3/T4 hybrid?
Also, will there always have to be a custom downpipe when doing ka-t? (unless the company that sells the turbo has a downpipe for it). I don't see how I'd get one made without towing the car to an exhaust shop for fitting.
lrb_2000
Car: '91 Nissan KA-T hatch
If the manifold says it uses T3/T4 flange, then it's for both. There should be two different bolt patterns on it.
hannibal
Car: Red Line to Glenmont
^ yep. T3/T4 hybrid means it has a T3 turbine and therefore needs a T3 manifold.
Unless the mfg'er of the manifold also produces a downpiipe, it will have to be custom. JGS and IAP sell a downpipe with their manifolds.
FYI, the GT32 uses a T3 inlet flange...
Neejay
OMG finally a straight answer. I've posted this one 2 other boards without it being answered. Thanks a lot guys.
