i clocked my turbo and thought it was all gravy, put on gasket maker on manifold and downpipe and have everything bolted up
and now i realize my banjo fitting for coolant is angled down and it is leaking, and i cant get to it unless i clock the turbo again, not only that my oil return is hitting my mani, causing it to burn
real big piss off and i have unbolted all the bolts for the compressor side and exhaust side of the turbo, they arn't off just twist able and i still cant move the center peice to clock it
do i have to take the whole turbo off again just to clock it and then put it on again? this will be a big pain in the a** and i need my car running tomorrow! need quick help please!
z31 turbo if it helps
