It was a 1 time deal by the company Drift Motion. I purchased it before Garrett forced a nationwide price match with all its dealers.matty wrote:show me where you found a gt28r for 600 new, cheapest i found was 790 new.
were talking a genuine garret unit right? not a no name knock off?
nocwage wrote:T3 Super-60 is probably the best BUDGET replacement.
It's a good match to the CA18, the lag isn't that bad at all and you can make 250whp no problem with it.
I had a weird problem with my butterfly valves that I discovered too late to correct my tuning much but I made 223whp at 14.5 psi on my T3 super-60 setup and I know I will make a lot more in the summer when I can start tuning the car again. (My silvia doesn't play in the snow)
The T3 Super-60 is CHEAP.. mine was $535 CANADIAN for a brand new one.
What´s the max power you´ve seen using a .48 turbine housing?We maxed a Turbonetics out at 400bhp but all turbo´s are different.BACARDI_DWB wrote:yeah with a .48 exhaust housing to assist in faster spool. boostboy has told me to stick with a very small exhaust side to maintain good spoolability
Haha, I guess the .48 housing is the best option for a 300hp engine but I´ve always used bigger because of the cost, not the need.BACARDI_DWB wrote:well there is a good reason that the GT35R's only put out a .63 housing. i think you are right on that .48=400hp or in that area. i wouldn't want to push it more than that in case of surge/backpressure. I plan on running .63 on a GT35R but that is me. Im special, my mommy says it every day
We can´t buy the smaller turbine housings to the same prices as you do and that´s why we use bigger ones.Only tried .48 one time at a 1.8 litre and it maxed out 50 hp before the limit Turbonetics gave us. A .63 solved the problem but laggy as you say.You can always learn to drive a laggy engine on both track and daily and that´s what we´ve done in the CA case.My favorite CA turbo is the Mitsu ones from Volvo but that´s also because we get them cheap here, 200-380hp depending on size but they all got big turbines because of the 2.3 and 2.5 litre engines they are from.BACARDI_DWB wrote:well when you say that you "use bigger" is that on personal cars or the drag cars that you built? cause on drag cars (depending on gearing) you normally want a larger ar housing due to the ability to run larger boost levels on smaller turbo's with not running into surge. they can prestage and rev limiters to launch off the line already in boost and not have to worry about lag. street cars/drift/autox cars all need to beable to spool quick for throttle response. just wondering what you used personally
