GTR PrYdE wrote:Under 1000 might be unrealistic once you add EVERYTHING that it takes to convert your car to boost..
A used garrett T25 is a great turbo on a super cheap budget, so are 370cc injectors. It would be good for your goals, probably 200whp-220whp.
CXRacing is still ebay stuff, though they probably have a better rep than most ebay turbos. Emusa has some decent turbos too.
CXRacing will have your intercooler kit,exhaust. Basically non moving non-cirtical ebay parts are ok without worry.
Go Enthalpy or another recommended mail order rom tuner.
You'll need the fuel pump/z32 filter.
Not sure how much power the auto's will hold, but converting to 5 speed can be pricy too on a budget, especially once you factor in a clutch.
Don't forget about gauges too... bascially all the stock ones suck, even the tach... Need water temp,oil pressure, boost, wideband AFR
Good luck!
It's funny you sent me that link cause that's the turbo I was looking at. Yeah I'minterested if you happen to stumble across that. That 9-3 Garret would do the trick huh? I may give him an offer. The SR manifold would be a good pick for me.Jmoore124 wrote:I own a 2003 9 3 convertible. I know mine has a 4 bolt manifold flange and a 3 bolt downpipe flange. I don't know what manifold you are planning on using, and the exhaust downpipe will have to be fabricated. I looked around on ebay a little bit and it looks like the 9000 in the early 90's had a similar bolt pattern. If I were you, considering your horsepower goals I would get a SR manifold and the t25 or 28. I am not 100% sure how, but I know some guys were running the SR manis on the KA. I have one laying around, if I can find a KA flange to weld to it if you are interested. At that point, with a Reman turbo from ebay (299ish) and a Custom Sr log mani (150) you would have a very inexpensive Mani/turbo setup.
http://www.ebay.com/itm/Saab-900-93-9-3 ... es&vxp=mtr
For 125, I know they have rebuild kits for like 60 bucks.
Having said all that, I would personally go to a pick a part and look for something slightly newer. Last time I was at a local lot there were multiple running 9-3's that had been crashed with less than 100k on them. You could pull it yourself and probably walk out with a unit that is not two decades old for 150.
Thanks, I made a powder coating cabinet over the summer before I built the car to start a small business. Def. comes in handy.
I think you just called me a Dummie!AZhitman wrote:I'll drop my 2 cents - SAFC is for kids and dummies. If you can't afford a proper tuning solution, don't boost.
Also, if you need bigger injectors, hit up Deatschwerks (see article on homepage).
Supposedly the ISIS V2 T2 manifold is thicker than the normal ebay manifolds. At $200 that seems fair to meJmoore124 wrote:There are a lot of horror stories from those ebay manis though. Boost spikes to cracking.
Thanks this is very helpful, what about the t25 from Godspeed? Wouldn't that be an ok turbo to use? http://www.amazon.com/Godspeed-Universa ... auto_img_y I know the adapters above would work too.WDRacing wrote:These turbo's are balanced. They're the best of the Ebay Chinese turbo's. Here's a 2871. It'll give you almost instant boost and be good for 14psi before it becomes a heat pump.
http://www.amazon.com/gp/product/B0067R ... d_i=507846
You'll need these adapters.
http://www.amazon.com/gp/product/B0042R ... d_i=507846
http://www.amazon.com/89-98-Nissan-240S ... 0+downpipe
Use with any bottom mount T25 style Ebay manifold.
Here's the ISIS V2, supposedly thicker steel.
If you buy a used turbo and need a rebuild or blow a turbo and need it rebuilt, go here.
http://gpopshop.com/services/rebuilding/
If you're on a budget and don't plan to exceed 8 psi use a 8:1 FMU and a small bit of timing retard at the distributor. This setup will require the fuel pump you mentioned. Stay away from the SAFC. The FMU works great, is cheap and requires no tuning.
http://www.summitracing.com/parts/vor-6 ... /overview/
If you do choose to invest in a fuel system with a ROM tune, don't get anything smaller then the 550cc injectors, a N62 MAF and the Enthalpy ROM tune to match that combo.
The FMIC and piping can be any cheap Ebay kit. At most you'll end up replacing the cheap couplers with heavier silicone ones.
Yes for sure. The T25 is inefficient even at 5psig on a KA. A T28 will still spool very fast and handle 200-300whpMr240dude wrote:Even for my HP goals? I'm probably better off with a new godspeed than a used St 25 anyway
