turbo change question
slw240sx
Car: 1990 Ca18det 240sx Hatch
ok guys im lazy and tired im not searching this, and this is becoming a close knit family so i doubt any of you care if i just post a question with out looking,
the stock t25, does it have coolant lines in and out of it !? my car is too far away to go look, the fsm says it does but its vauge to say the least !
im putting in my HKS gt turbo this next week it has the oil lines, but no coolant lines they are open on the turbo ! will i need new lines, or will the stock ones, if it has them mount to it ? can i run the turbo dry, if so is it a bad idea !
thanks guys jon
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
the turbo could just beoil cooled instead of both. but i am not too knowlegable on turbos, and cant afford a hks, so im afraid i cant help you much.-tim
chezina
Stock t25 is water and oil cooled! Fittings are there already.
slw240sx
so they use water cooling from factory, will those lines fit up to anyother turbo!?!?
chezina
As far as i know u have to change the oil feed line for every other turbo(t28,t3 etc.), don't know about water lines if they line up or not.
themadscientist
assume the oil line is coked up and get a new oil line. HKS sport GT turbos in their catalog don't come with any new water lines, this would lead me to assume they hook up to the stock water lines. Being as the factory and HKS turbos are both Garrett products it seems a safe assumption.
CA18Fastback
this may be a bit off this subject, but where can i get new turbo lines(maybe stainless steel) for when i get my new turbo?
Thanks!~Ian
slw240sx
one step ahead of yah Mad, i got the new oil line when i got the turbo! and the question as to where to find lines is right on topic ! cause that was going to be my next question, i want to get a SS braided oil return and maybe new coolant lines
