Turbo Cars/ Exhaust// No Exhaust HP/TQ Gain Loss? Questions
FinkenS14
Car: 1995 Nissan 240sx S14
Hey guys I got a question. With my RB Im running open turbo elbow right now, and my question is, am I losing power without running exhaust?
Im paying a buddy off for his 4" exhaust hes selling me, and when its paid, Im putting it on, but till then, am I losing HP and TQ till then?
The way my friend expalined it to me was turbos like hot exhaust gasses, the hotter you can keep the turbine side, the better...hot gasses flow faster then cold, hence more flow and back pressure.
So ya...thanks guys
kouki munster
Car: 97 base 240
Not hurting a thing but your ears.
tEknoS13
Car: 93' Type X
I don't see how you would be losing power. The RB is turbo. Your might actually be freeing power. The faster you get rid of exhaust the better. I don't know about the back pressure, thats mostly a NA motor thing. Ex: KA
Isn't that like incredibly loud?
kouki munster
Car: 97 base 240
tEknoS13 wrote:I don't see how you would be losing power. The RB is turbo. Your might actually be freeing power. The faster you get rid of exhaust the better. I don't know about the back pressure, thats mostly a NA motor thing. Ex: KA
Turbo motors have a lot of back pressure, before the turbo, so the less restriction you have after the turbo the better.
FinkenS14
OK, so this makes no sense???
Its really not that loud...maybe you just have baby ears
tEknoS13
Car: 93' Type X
Glad you corrected me since I was giving wrong info to the OP.
But still, less restriction=
killernoodle
Car: My daily: 2005 Cadillac CTS-V - pretty much stock
Brother's S13 project car: SR20det, wilwoods, suspension, q45 diff/axles, 315s out back
Psssh, a turbo is the only muffler you need.
E7-S14
Car: ess 14 foo!
i ran open DP with my setup.
a little quieter and sounds a lil better than open elbow..but for street.. id do full catback.
FinkenS14
My question, and the original information that I provided about exhaust and turbo dynamics still hasnt been answred....
mynamesmark
Car: 98 s14, 89 Coupe, 92 z32 2+2
NO, you are not losing power. Simple answer.
kouki munster
Car: 97 base 240
killernoodle wrote:Psssh, a turbo is the only muffler you need.
The exact reason I run the buddy club spec II exhaust, its basicly a an open down pipe that exits at the rear bumper.
FinkenS14
But that is STILL a full exhaust, and there has got to be a power gain atleast in torque from that
kouki munster
Car: 97 base 240
I'm willing to put money on that the only way to tell any differance in power between an open elbow/down pipe and a buddy club spec II will be to put it on a dyno, and if it is more than a 5 hp/5 ft/ib tq differance I'll s*** bricks. And the differance in power will most likly be in favor of the open elbow/ down pipe.
So once again YOU ARE NOT HURTING A THING BY RUNNING AN OPEN TURBO ELBOW.
And to more acuratly answer your question, the more heat that stays in the exhaust before the turbo the more energy(hotter exhaust gasses) you have going through the turbo which will help it to spool faster. After the exhaust goes through the turbo the only thing you want it to do is get the f*** out as fast as possible.
You could have spent 10 min on google and got that answer, but instead you were lazy and wanted someone to spoon feed you the info.
Modified by kouki munster at 5:16 PM 8/30/2009
Elbowblk
Car: 95 240sx
what about the o2 sensor on the elbow?
kouki munster
Car: 97 base 240
What about it?
FinkenS14
Its like an inch away from the edge of the flange, hence, fresh air is constatly getting rushed back in.
kouki munster
Car: 97 base 240
About the only time that the o2 will get any amount fresh air is when you turn off the car and exhaust gas is no longet flowing out. Remember for ambiant air to get into the exhaust the pressure in the exhaust has to be lower than the ambiant. Now I'm not saying the o2 will never see fresh air while the car is running but the times it does will be short and have little to no effect.
FinkenS14
Riiiight, so thats why cars get s***ty gas mileage when they have an exhaust leak by the o2 sensor, im done here, thanks for no help at all.
kouki munster
Car: 97 base 240
I'v never heard of a car with an exhaust leak by the o2 getting bad gas mileage, bad o2 sensor causing it but never a leak. But I could see a leak causing that, depending on the shape of the hole, the exhaust flowing by the hole could cause a venturi effect and suck in fresh air, but it would have to be up stream on the o2.
For f***s sake if your f***ing worried about it stop being a little b**** and and put an exhaust on your car or stop driving it untill you do, is it really that hard for you to figure out on your own.
FinkenS14
Someone seems to be getting a little frustrated
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
U might actually be gaining horsepower...however ur losing torque without the exhaust...I say slap on a buddy club spec 2 exhaust
kouki munster
Car: 97 base 240
FinkenS14 wrote:Riiiight, so thats why cars get s***ty gas mileage when they have an exhaust leak by the o2 sensor, im done here, thanks for no help at all.
FinkenS14 wrote:Someone seems to be getting a little frustrated
I could say the same about you, especially when you get an answer that you don't want hear.
Anyways, you should just go kill yourself now as that would be the best thing for everyone at this point.
FinkenS14
LOL
sr20power
Car: S14 Zenki
this thread is stupid....! OP do your own homework.
FinkenS14
I did do my homework, how the hell you think I got my information in the original post, I was just verifying information and mr captain america had to go all mr bad a** on the interwebz, i find it hilarious
kouki munster
Car: 97 base 240
FinkenS14 wrote:I did do my homework, how the hell you think I got my information in the original post, I was just verifying information and mr captain america had to go all mr bad a** on the interwebz, i find it hilarious
Are you trying to apologize now?
If you are, I accept your apology, because you called me captain america (flatery will get you every where with me ) and we all know that captain america is a bad a**. (in a good guy way)
Ilvemynissan
Car: 240sx s13
This is a little off topic but a good read nontheless. It's a recent thread so people will still be adding on to it later.
http://www.northwestnissans.co...99917
