Turbo ca18de
Ca_laurier
i am not talking about the ca18det, but the jdm ca18de.
can anyone tell me the advantages and disadvatages of running a high compression turbo engine? and has anyone done this. I fried my original ca18det andam looking into some options and came across the na ca18de and a friend of mine told me its been done but if i go this route instead of waiting for another ca18det what are the problems i would run into. i will be changing the injectors, and swapping over everything.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Ca_laurier wrote:i am not talking about the ca18det, but the jdm ca18de.
Float_6969 on here is running a high compression CA. But he is doing it on a DET block and forged pistons. Big difference. DE block has crappy cast pistons, no oil piston squirters, no crank girdle...
Ca_laurier
well i have a ca18det block, but the walls in the 4th cylinder of scratched to hell. could i swap everything over and use the ca18de block but the ca18det internals?
c-rad
Ca_laurier wrote:well i have a ca18det block, but the walls in the 4th cylinder of scratched to hell. could i swap everything over and use the ca18de block but the ca18det internals?
Why not bore the DET block and get some oversized forged pistons? Also, I believe that you would have to drill and tap the DE block for an oil feed for the turbo.
Ca_laurier
wow, i totally over looked the oil feel. thanks for the advice i am probably going to just wait for another ca18 to come in
themadscientist
DE block has a girdle. At least the JDm one does. I am not a dogmatic follower of piston oilers. I would prefer to use forgies and save the oil that would have shot out the squirters to keep the crank floating on the bearings.
CA19DET
i am running a JDM CA18DE block,
it DOES have the girdle, the rods are the same, no oil squirters, i am running DET pistons though, 300whp, no worries
