TURBO / BOV SUGGESTIONS???
RIPCAT
Car: 1990 240sx
I currently have a T3/T4 turbo but I think its a little too big for my car. It takes forever to spool up and the only time I have any blow off is when I'm constantly red-lined.
I want a decent sized turbo that will spool up nicely, sound great, and still deliver the boost I desire
Also, any suggestions on a nice BOV?
Gabes13
Car: rb20det s13
I heard that s15 t28 was pretty good.
As for bov... I think the hks is over-rated.I like the greddy rs one better
AZ89two4Tsx
From what I've heard from the guys in the KA-T forum (where this thread should be ) a T3/T4 is perfect for the KA. But if you want quicker spool, go with the T25 or T28, duh.
As far as bov's, I don't care if people call it rice/overplayed, I like the hks ssqv. The Greddy ones sound nice as well. It's pretty much personal preference. Also, are you recirculating or venting it? That has an effect too.
Oh btw, I'm assuming this is KA you're boosting?
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
T25 T28Ct26etc.
BOV - HKS SSQV, i don't give a screw if it's boy racer/played out/rice. it does the job better then anything else......unless you go Tial but thats some more money..
RIPCAT
Car: 1990 240sx
AZ89two4Tsx wrote:From what I've heard from the guys in the KA-T forum (where this thread should be ) a T3/T4 is perfect for the KA. But if you want quicker spool, go with the T25 or T28, duh.
Yeah sorry, its a KA. I am venting but the BOV I have right now is a POS. Im not sure what brand it is, it came with the car but I am sure its a knockoff.
tEknoS13
Car: 93' Type X
GT28RS and Greddy RS bov.
Logan76
Car: Junk
Stay with the T3/T4, try to find out some more info on what turbo you have on there, and the exhaust A/R. Is it possible you dont have your bov adjusted correctly? Unless your getting compressor surge I would say that your good. How many lbs of boost are you running?
S14toRPS13
Is your bov adjustable. I'm not sure about yours, but with my blitz bov, I had to play around with the adjustment to get it just right. Stiffening it up too much causes compressor surge. Softening it up will get the cool woooosh, but it causes stalling. I'm not sure if yours is the same way.
adrianfromthecastle
Car: 1992 Nissan 240sx
I had the Greddy RS bov... it sucks for venting. At stock boost, it did me no justice. With both springs in and at its softest setting, it wouldn't open. With 1 spring in and at its hardest setting, it still wouldn't open. Then with 1 spring in and at middle to low setting, I'd stall when tossed into neutral too bluntly... I was never satisfied.
However, I switched to the HKS SSQV. It worked great vented. No need to adjust anything, and it closed and opened when I wanted it to. No stalling whatsoever. I have really no complaints about them (other than that everyone else has it)
As far as turbo goes... my fav is the gt2871r .86It's a bit more laggier than the .64, but the end result is a slight more power... but regardless, its might be more responsive than your previous t3 setup
Logan76
Car: Junk
I agree with adrian if you do decide that getting a smaller turbo is a "must" the GT2871R is your best bet, and you can get it with a T3 flange so you dont have to get a new manifold.
DevilMB3017
A T3/T4 turbo will take longer to spool, but move more volume of air and lower spool.
So you might only get lets say 5 lbs at 4K RPM, but your moving way more air then a T2-flange turbo at even 7-8lbs at 4K RPM. And we all know more air=more power... right? Right.
The HKS SSQV is possibly the easiest BOV to use. There are 0 adjustments possible - so it always is working properly. It might be "played out" but thats because it works the best.
RIPCAT
Car: 1990 240sx
I looked into that SSQV BOV and daaaammmnnnn..... it sounds nice
I think I might keep my T3/T4 turbo and get that BOV. I'm hoping I'll have better blow off with that.
480sx
Car: 1996 Pearl White 240sx
Saying you have a t3/t4 really tells us nothing dude.
You could have a t3/t4 with a 62-1 wheel and a P trim 1 ar housing for all we know.
Or you could have a small t3/t4 thats blown. Or your wastegate is faulty, or has a low spring in it. SOO many different things here that could be causing your issue.
First, figure out what kind of turbo you have and who makes it.
DevilMB3017
RIPCAT wrote:I looked into that SSQV BOV and daaaammmnnnn..... it sounds nice
The reason I suggest it isn't for the sound, it's because there is no adjustments to make. There isn't anything to mess up or break or anything to worry about messing up...
AZ89two4Tsx
adrians_s13 wrote:I had the Greddy RS bov... it sucks for venting. At stock boost, it did me no justice. With both springs in and at its softest setting, it wouldn't open. With 1 spring in and at its hardest setting, it still wouldn't open. Then with 1 spring in and at middle to low setting, I'd stall when tossed into neutral too bluntly... I was never satisfied.
Sooooo....with the ssqv there is no NEED to recirc it? I love the sound. Sorry for the fanboyism, lol.
480sx
You dont have to recirc it, however its going to backfire between shifts and stall out when idling down after boost if you dont.
adrianfromthecastle
I will however say that the stall out isn't going to be as bad as any other non-pull type BOV.
Pull type bov's win in my book.
AZ89two4Tsx
So recirculating is the better option always right? I was considering a blow-through setup, but I don't think I care that much, lol. How much quieter are recir'd bov's?
480sx
You still hear them quite clearly, i recirced a customers car with freaken 3/8ths inch thick tubing and it was still clearly audible. Recirc is the way to go for a daily, trust me.
Logan76
Car: Junk
I ran atmospheric and I didnt have any stalling issues, maybe a little dip in idle or so but never a complete stall out, that was with a Greddy bov.
AZ89two4Tsx
480sx wrote:You still hear them quite clearly, i recirced a customers car with freaken 3/8ths inch thick tubing and it was still clearly audible. Recirc is the way to go for a daily, trust me.
What the norm for diameter as far as tubing goes then? Around 1/4 I'm assuming?
480sx
No, the recirc fittings are usually about 30mm. They vary from company to company, but none as small as 1/4th, your talking about a lot of air that needs to be moved.
Tial makes the best all around BOV's on the market IMO, and through many tests. They have a new one that looks like a bong, the Alpha Q which allows recirculation. They are pricey, but very high quality BOV's.
