boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Wed Jul 07, 2004 5:59 pm
Quote »I don't totally agree with this. The oil enters the intake piping via the PCV system. My rings WERE bad and I was getting blowby. I'm rebuilding the motor right now and I know I was having problems and I WAS gettting oil in my intake piping. It was greatly reduced when I got an oil catch can, but it didn't totally fix it. I think the way to check would be to see if there is oil on the suction side of the turbo. If there is then it's blow by and you've got bad rings. If it's not on the suction side and ONLY on the pressure side, the I'd go with Dee and say it's a blown seal....[/quote] This would only apply if you route your ventilation tube from your exhaust cam cover back into the intake system as it was intented from factory. Then and only then will you get this effect. Most members including myself have left the breather tube open, hence you hear some people saying they get oil all over their engine bay.
Oil will not exit through the intake manifold unkess you just got major problems and even then, it will still have to clear the throttle plate which is why I can't see oil going backwards through your intake system, out the throttle plate back down through your piping and out through your BOV. It would normally come from the cool side of the turbo. The best thing to do is inspect the cool air output of the turbo and look for oil. I'm 99% sure you will see it. Most CAs that come from Japan with stock intake tubing will have oil in them.
Quote »Well, it happened to me, I was getting oil spitted out of the bov, turbo was full of oil from the intake side and exhaust side, (I thought my brand new t28 turbo blew), then I rerouted the valve cover line to a bottle (this line usually goes from the valve cover to after the afm), I never had oil spitting out of my BOV ever after, and the bottle got some oil in it, when ever I push the car.[/quote] This is exactly what I'm saying! It can only dump oil into your intake via the breather tube on the exhaust cam cover. If your getting oil through your intake manifold and out your throttle plate "Dude" your engine is soooooooo done.
He never told us how his breather tube is routed, so as of right now, we're all speculating, but neither of us is wrong. I know what blow-by is and these engines are notorious for it, but it doesn't mean that they're completely broken. Just keep going until it starts smoking or it starts spitting-up too much oil.
Dee
